Rise and Fall in Manual mode
Discussion in 'ALTA' started by Aj White, Sep 15, 2015.
  1. Aj White
    Aj White Member
    Feb 14, 2014
    82
    Hey guys, been flying as much as I can getting my bearings. I have been using a pair of 6000mah batteries until all my Freefly ones get here in a few days.
    I flew once with nothing else attached and then once with some more batteries as a dummy load in the bottom tray.
    Both times the throttle is EXTREMELY sensitive and I find myself struggling to keep it at a steady altitude. I'm pretty sure it's because my load is so light and it's at almost .25 throttle/hover right now.
    Would a poor compass calibration also have something to do with it? I didn't have a friend with me at the time but I'll re-do it tomorrow.
  2. Tom Pattison
    Tom Pattison New Member
    Sep 9, 2015
    Your alta is too light and you don't have enough throttle control at quarter stick. I did the same and struggled to land ;)
  3. Gary Haynes
    You can land while in Altitude Hold. When light the throttle takes less input for changes.
  4. Aj White
    Aj White Member
    Feb 14, 2014
    82
    Yeah that's what I figured, thanks guys. I did try the altitude hold and it works beautifully.
  5. Chris Jordan
    Chris Jordan Member
    Dec 4, 2013
    118
    16
    If all else fails.... Read the manual before take off, it actually talks quite a bit about this :)
  6. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    Look in the manual for setting hover throttle. pg 33 in the smaller setup guide manual. I highly recommend changing this for changes in payload.
  7. Aj White
    Aj White Member
    Feb 14, 2014
    82
    Thanks guys, I got it all sorted the next day. It was just due to payload weight. All good now.
  8. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    Hi, I am having a similar issue. After a few adjustments to the hover throttle I managed to get the ALTA to hover at centre stick, but it is very sensitive. Just one notch up or down has a huge effect on the ALTA's climb/decent rate. Not sure if this is normal for most pilots, but I am definitely not used to this level of sensitivity.
    I was carrying a payload of 2.7kg bottom mounted and had the flight batteries on top. Is this too light for the ALTA? Should I increase the throttle expo to make it less sensitive?
  9. Mateusz Hajdziony
    Jul 10, 2013
    80
    Sounds as a pretty light payload for the ALTA and that's probably why the craft is so sensitive to the throttle. Setting expo on the throttle in your Tx should do the trick!
  10. Gary Haynes
    Or try the Expo settings in the ALTA. In the GUI - Radio - Adjustments page.
  11. alex ryan
    alex ryan Member
    May 8, 2015
    227
    16
    cool, thanks for the conformation. Most of the time I'll be flying more weight than this obviously. I just got my ALTA, so these flights were just with a dummy load to put some weight under her.
  12. Aj White
    Aj White Member
    Feb 14, 2014
    82
    I'd love to get a little more info on this. You're saying this will tame down my manual controls? I'd love to mellow out the throttle response, it's like Fast & Furious out there.
  13. Gary Haynes
    AJ I haven't tried them yet, and just noticed there is nothing in the manual. So I making an assumption they would work like the EXPO settings that you can do in a radio like the Futaba. Worth confirming with the support team at FreeFly.
  14. Zac Eskelsen
    Zac Eskelsen New Member
    Jun 3, 2014
    26
    I don't notice much response from the expo in the app, but if your using Futaba you can set several different throttle expos, and set them to a switch so you can try several different ones quickly.
    I've adjusted my expos in the radio and just watching the values in the app I already can tell its going to be much less sensitive.
    I can make a little explanation video if requested about how to make the changes in the futaba, (or spectrum for that matter).
    Kurt Naeslund and MIke Magee like this.
  15. Will Glover
    Will Glover New Member
    Dec 12, 2015
    18
    Hi,
    Just picking up on this.
    We're flying the Alta at maximum weight currently. I was wondering what the best hover throttle setting would be voltage wise for this? It'll save me landing testing landing testing as we're on a shoot.
    Thanks,
    Will
  16. Kurt Naeslund
    Kurt Naeslund New Member
    Oct 24, 2016
    20
    Hello Zac!
    Did you get to make that explanatory video?
    I am struggling with a overly "agressive" Alta 6, and I am a newbie.
    Thanks,
    Kurt Naeslund
    Norway
  17. Colt Helton
    Colt Helton New Member
    Feb 22, 2017
    Kurt, Did you figure you're problem out? Having the same issue
  18. Kurt Naeslund
    Oct 24, 2016
    20
    I must admit, practice...that is one thing that helped me. When writing my initial input here I was flying the GH4, and it seemed pretty light for the Alta6, så more weight is actually needed. I am still having problems getting it to hover at 50% throttle in manual though, even when flying a heavier camera now...
