Anyone know if there a way to reset the Roll Trim default or zero on the controller? Thanks in advance.
Hey Andy, Yes of course. If you go to the TX Monitor screen, you can view the current roll settings. (It would be great if in a future firmware update, you could press and hold both roll buttons to reset it) Another great tip from Brad: If Pan and/or Tilt aren't at '0', you can "re-zero" them in the TX Config > TX Action menu, which will re-center the rig. Additionally, if you turn on the controller while holding pan or tilt, it will set that as zero during boot. It will not zero roll, however. That still needs to be done via the description above. Hope this helps. Cheers,
