Hi, can someone help me please to setup the movi for two operator mode please. I have a futaba 14sg. I have plug the rx (r63202sbw) on the movi sbus and link it to the 14sg. After some times i could have the movi to move but i don't know really well how to setup the radio. I have see the channel mappinf on your site but nned more info : 1. Which model type i have to choose (helico, avion...) 2 can you explain me how to map the channel please ? Is there any tutorial avaible online ? Also other questions : - can i remove the spectrum cable if i use only sbus ? - is it a problem if i remove the futaba rx and let the sbus cable with nothing at the end when don't use it ? - what is the cable which look like an antenna next to the sbus (on photo) Thanks
Semiond: This may help (at least with the Futaba side of things): http://forum.freeflysystems.com/ind...ng-the-futaba-radio-on-the-alta-6-and-8.7821/ Andy Forensic Software & sUAV / Drone Analyst : Photographer : Videographer : Pilot (Portland, Oregon, USA): Trees=2, Ground=1, Props=11. The Ground Is The Limit™ ---------- Forensic Drone Analyst : Forensic sUAV Analyst : Forensic Unmanned Aircraft Analyst : Forensic Drone Expert
Hi Semiond, Here is a great tutorial from Jeff at Quatrocopter: Wayne Mann www.HeliCamHighDefmedia.com
