Removing roll potentiometer for Radian install?
Discussion in 'Radian' started by Andy Johnson-Laird, Sep 18, 2012.
  1. Andy Johnson-Laird
    10,369
    I'm just installing the production Radians.
    Images 3, 4, and 5 in the Radian documentation show that the roll potentiometer has been removed. Is this just for visual clarity of how to install, or do we actually need to remove the potentiometer?
    There's no reference to physically removing the potentiometer in the Radian manual (other than to say they're not used).
    I have a funny feeling that removing the potentiometer might be a Bad Thing..... :)
  2. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Rip that thing off Andy ;) Dead weight now
  3. Andy Johnson-Laird
    10,369
    Thanks for the rapid reply, Tabb. That crunching noise is not me landing in the tree again, it's a pot being ripped off.... ;)
  4. Jose Luis Ocejo
    Jose Luis Ocejo Active Member
    Sep 20, 2012
    581
    44
    Hi I got my gimbal a month ago I have not taken it apart yet, so I have some basic questions...ok so take the 2 potentiometer copletly off I take it that the shaft that holds the wheel on the roll is not part of the potentiometer, what about the tilt if I take the potentiometer of what shaft does the tilt pivot on?
    thanks
  5. Tabb Firchau
    Jun 28, 2012
    911
    472
    Hi JLO, to remove the roll potentiometer just remove the mounting bracket and loosen the setscrew in the roll pulley that holds the pot shaft. You can then remove the roll pot. For the tilt pot you need to leave that installed for now to support that part of the gimbal. We will offer a bearing and shaft option for that half of the gimbal in the future.
    Best,
    Tabb
  6. Janne Hoglund
    Janne Hoglund Member
    Oct 4, 2012
    364
    23
    So in the future you will be able to by a Radian adapted version of the gimbal, as well as the std one?
    Regards.
    /Janne
  7. Tabb Firchau
    Jun 28, 2012
    911
    472
    HI Janne, in the future we will likely offer the gimbal without potentiometers.
    Best,
    Tabb
  8. Janne Hoglund
    Oct 4, 2012
    364
    23
    Thanks Tabb.
    Regards.
    /Janne
