Hello, I just tried to bind my Movi M10 to my Taranis remote. Everything works just fine except for the Pan. If I go to the Dual OP in the app I can see the Pan is working in there but the Movi just doesn't react to the input. Roll and Tilt are working fine though. Anybody knows what I am doing wrong?
I think the problem is the mode switch, I can't see that one changing in the app. Is there a way to set the mode in the app without using your remote? I did set a three way switch to channel 6 but it doesn't change at all.
Got it! Don't know whether it's the best solution but it works. For people with the same problem what I did: Set the mode switch to channel 1 in the app (the one that's 6 in default in the Dual OP menu) and changed channel 1 from my throttle stick to a 3 way switch on the Taranis and now everything works!
