I have special case where i need to control the movi thru a computer and was wondering if anyone has had any experience sending it pc commands? The pc can be connected to a radio control to actually send the commands but looking for some hints on where to look about remote controlling the actual controller.
Interesting problem. I presume, technologically speaking, you would need to have some way for the PC to emit the same data stream as either a Spektrum Satellite or Futaba receiver. I've seen some references to doing the Futaba using an Arduino -- but not seen anything about using a PC except perhaps this http://www.instructables.com/id/Put-your-RC-car-under-computer-control/ (which didn't exactly fill me with confidence!) Andy.
how many buttons on the radio controller would you need controlled by the PC? Perhaps if you only have a few buttons, you could rig a micro controller (like an Arduino) to a series of solenoids and servo motors to interface with the radio controller. The benefit to doing it this way is that you know it will work, and if you ever need to manually override it will be obvious. Good luck
Thanks for that, Mark. Looks like you still need to write some software, albeit they do provide example source code so that would be muc easier that starting from scratch. Andy.
