Red RCP cable & Red start/stop cable
Discussion in 'MōVI Pro' started by Tyler Oxendine, Jan 20, 2017.
  1. Tyler Oxendine
    Tyler Oxendine New Member
    Jan 8, 2017
    What is the difference in the Movi Pro Red RCP cable & the Movi Pro Red start/stop? Any need to have both cables?
  2. Ryan Forte
    Ryan Forte Member
    Oct 5, 2015
    69
    No get rcp if you want to control camera settings.
  3. Tyler Oxendine
    Jan 8, 2017
    So no need for the start/stop cable if I have the RCP cable?
  4. Ryan Holdridge
    Nov 6, 2016
    37
    13
    No Need - If you have the RCP cable, you can start/stop the camera as well.
    Ryan Forte likes this.
  5. Olli Koivula
    Olli Koivula New Member
    Jan 25, 2017
    I'm having trouble hooking up the rcp cable. Do I need to make some settings on the epic or should it work by just plugging the cable?
  6. Ryan Holdridge
    Nov 6, 2016
    37
    13
    I believe you have to turn on serial communication once the cable is hooked up.
  7. Graham Futerfas
    1,258
    243
    You have to enable it in the menu. I found it by using the 'search' function on the RED and just type in RCP.
  8. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    273
    84
    Starting with camera firmware 3.3.x, the RCP is available through the CTRL connector (RS232 port) on the rear of the camera body. The RCP is disabled by default, and must be enabled in the DSMC menu.
    1. Go to Menu > Settings > Setup > Communication.
    2. Select the Serial tab.
    3. Select REDLINK Command Protocol in the Serial Protocol drop-down menu.
      Once selected, REDLINK Command Protocol will be persistent across boots.
      Link: https://goo.gl/ByfQwd page 6
  9. Olli Koivula
    Jan 25, 2017
    Got it! Thanks guys!
  10. Navid Tansaz
    Navid Tansaz New Member
    Aug 20, 2013
    10
    Hi Guys, We are trying to make a RCP cable in house, but not sure if we have the pinout right. hope one of you might be able to help!
  11. Olli Koivula
    Jan 25, 2017
    Here's a pic of the rcp cable if that helps.
  12. Razvan Pestean
    Razvan Pestean New Member
    Jan 31, 2017
    Hi guys,
    I've got the MoVI Pro RED EPIC Start/Stop Cable and a RED EPIC W but I can't make it work.
    Did anyone else tried this setup make it work before?
    Cheers
  13. Olli Koivula
    Jan 25, 2017
    I couldn't get the start/stop cable to work either. But the RCP cable worked and it also does start/stop so I recommend changing to that.
  14. Razvan Pestean
    Jan 31, 2017
    Hmm, interesting.
    So what does this MoVI Pro RED EPIC Start/Stop Cable do? Doesn't seem to work.
  15. Olli Koivula
    Jan 25, 2017
    well it should start and stop recording.
    freefly doesn't sell the cable anymore as it is obsolete with the RCP cable. The RCP cable starts and stops recording and also allows you to control iso, frame rate, etc with the mimic.
  16. Razvan Pestean
    Jan 31, 2017
    I see. Good to know!
    Thanks!
  17. Bryan Edmonds
    Jul 3, 2014
    254
    126
    What Expander are you using on the EPIC W?
  18. Razvan Pestean
    Jan 31, 2017
    I'm using the: DSMC2 JETPACK-SDI EXPANDER
  19. Bryan Edmonds
    Jul 3, 2014
    254
    126
    On both of the Jetpack Expanders RED used a new start/stop protocol that is wired differently than previous generations. The MōVI Pro RED Start/Stop cable is wired for the protocol that is used on DSMC bodies, as well as the Base Expander for the W bodies. It won't work with the new protocol :(
    For the Jetpack Expanders, you'll need the RCP cable, which can command start/stop as well as other supported camera functions through the MIMIC or MōVI Controller.
  20. Razvan Pestean
    Jan 31, 2017
    Thanks for all the info, it's good to know.
    I'll exchange the cable for a RCP one.
    Cheers
