RED lcd monitor with Movi, which works . I think.
Discussion in 'MōVI M10' started by Charles Lim, Jan 3, 2014.
  1. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    Hi guys
    I just made a Custom RED monitor soft cable through Movi rig tilt Axis. The cable was not easy to make, by hand. I basically got the lemo Singapore folks to help me with this. Here are the pictures. I am really happy with this setup. I get to get full control and have access to playback, plus not worry about batteries for a monitor.
  2. Norbert Blenk
    Norbert Blenk Member
    Sep 12, 2013
    52
  3. David Callahan
    David Callahan New Member
    Dec 5, 2013
    Norbert, did you happen to take any pics while you were doing this? Could you upload a pic of your final cable and setup?
  4. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    wow norbert, that cable is thin! Time to get that cable and rewire it, through the rig.
    I would love to see your modded wire too.
  5. Norbert Blenk
    Sep 12, 2013
    52
    Hi Charles and David,
    unfortunately i did not take any pics while stripping it. But here you can see the result:
  6. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    beautiful! . but ho! you didn't run it through the tilt axis?
  7. Norbert Blenk
    Sep 12, 2013
    52
    Yes...No!
    I knew this to come.
    It's well thought. I am running different cameras on the Mōvi and once the cable is put through the axis it could not be removed.
    (And... to strip it down i did not remove the plugs - I hate soldering!!)
  8. Erich Roland
    Erich Roland Member
    Sep 27, 2013
    44
  9. Eric Ulbrich
    Eric Ulbrich Member
    Aug 16, 2013
    122
    24
    Nice! Did the same thing with my 4' red touch screen cable a few weeks ago. Vastly improves the flex in it!
  10. Charles Lim
    Charles Lim Member
    Aug 20, 2013
    308
    21
    looks like all epic movi guys are on custom wires now
  11. Pablo Zaracla
    Pablo Zaracla New Member
    Dec 17, 2013
    Hi Charles, can you say where did you order your cable? The brushless gimbal one is out of stock right now. Thanx a lot!
  12. Ben Ruffell
    Ben Ruffell Active Member
    Jan 15, 2014
    229
    33
    We are on custom loom for the Epic now. But I have found the best results are to not mount a Red LCD at all. I just monitor and transmit through the SDI and we plug in the touch for playback or camera adjustments.
  13. chris weger
    chris weger New Member
    Mar 25, 2014
    We seem to be doing a lot of run and gun style shooting and I think that the option of having the Red LCD on the bars would provide a good solution then constantly plugging it in and adjusting. Are there any other cabling solutions you guys have found? are there no long flexible cables available for purchase?
  14. Lael Camak
    Lael Camak Member
    Sep 9, 2013
    46
    I got Tom of Alpine-Electronics.com to make me a very flexible and lightweight 2' Red Touch LCD cable. Expensive, but well built.
    Try Julie@alpine-electronics.com or Tom at tom@ruppert-sales.com
    Alpine Electronics
    (408)278-7171
    All the best,
    lael
  15. Ben Ruffell
    Jan 15, 2014
    229
    33
    The Redmote is a good solution if your assistant is familiar with it.
    I have tried some of the lightweight epic touch cables, various success with them. Some DOA…
    Any cables attached to the rig affect the performance, and I am currently getting the best results with just a super flexi sdi, power, and Axis 1 power all in the same loom.
  16. Chris Jordan
    Chris Jordan Member
    Dec 4, 2013
    118
    16
    We removed all rubber and casing to wires too, but now it won't work.... Was the wire mesh sleeve supposed to stay? the tin foil too?
