Hi The other day I tested Mimic mode on my ALTA / M-15, and it worked perfectly Unfortunately I could not trigger REC from my MoVI Controller. If I'm in the TX Confic set it from Mimic back to normal, I could trigger REC, then I should go back to Mimic. Slightly a messy solution, and some unnecessary long recordings. I think that I have set a setting wrong. I use the universal start/stop cable that came with MoVI M-15, but it has also accessible via the Wedge and a LANC cable. (wich I don't use at the moment, just focus motor) My entered settings: TX Confic Rec Type: Momentary Rec Polarity: Normal APP Map Remote shutter: 0 Shutter Type: Pulse
Talked to FreeFly today. You can only trigger the REC in Mimic mode, if you are using the Wedge with a LANC cable. Pretty expensive solution I may say
