We have the Radian 3-axis set up on Sbus wiring (we bought our Octocopter pre-built). The manual only has a low resolution image of the connections. I want to make sure we have the correct wiring. Does anyone have a wiring diagram showing which pin number on which module connects to what ? Thanks
There are wiring diagrams in the documentation section on the Freefly site. Image 1 shows the 6 ports. Image 5 in the PDF is a good example of the Servo Connector Orientation. The white Signal Wire goes to the label side of the Radian. Power is on the center pin and ground is the pin on the non label size.
