I've got all the latest driver ,software and firmware setup. All the connection is fine and having angle demand value from all three Radians.The problem here is i can't write/update the setting to the either one of the Radian.It just show timed out in the update message box.Is there any way to fix this ? The system i use are as follow: Win 7 under Parallels Desktop on Mac FTDI driver 2.0828/2.0824 (both tried) Radian Firmware 1.03 (Check with boot-loader mode as well) Radian Software 1.1 Futaba R6203SB Receiver with T14SG Transmitter All cable connection match the manual
Hugo can you get a screen shot of the message with the various Radian screens being shown? That would help.
Hay Gary, problem solved. Windows regional setting cause the problem,so i change it to unicode. Run pretty good now. Hugo
Hi Hugo! I have the Timed Out problem too.Can you help me out?I did not get how can i do changes in Window regional settings.where,how? Thanks for reading Jozy
Please check the following link. http://windows.microsoft.com/en-us/windows-vista/change-the-country-or-region-setting
Hi Hugo! I have same problem,I also have the Timed Out problem now. Can you help me too ? I checked the Location tabhe in Control panel as your following link. Bit I can not solve problem yet. Please tell us reply. Kiyofumi
