Radian Problem
Discussion in 'Radian' started by Andy Chen, Jan 21, 2013.
  1. Andy Chen
    Andy Chen New Member
    Oct 14, 2012
    Hi
    Here is a video explain the problem, please check it here :
    I'm using the Cinestar 3 axis gimbal with 3 Radian stabilization modules.
    The RC part consist of a Futaba T12CHP remote and a S.Bus transmitter/receiver system.
    I have updated the firmware to version 1.03.
    Voltage of 6V is using receiver
    Any help and suggestion is greatly appreciated!
    Thanks,
  2. Josh Lambeth
    1,315
    216
    Can you post a video or a screenshot of your Radian settings on the computer? Do you have your Radian setup with a mode switch? If so, what mode are you in? What happens if you turn it off and back on? Also make sure that you have it set to the tilt module in the software... it almost appears like it's programmed for a different axis and since it's going out of wack it's shutting itself down as the fail-safe... please confirm it's set to the tilt-1.
    Josh
  3. Josh Lambeth
    1,315
    216
  4. Ben Hall
    Ben Hall New Member
    Jan 20, 2013
    19
    looked like input power problem to me . as soon as the servo moves the rx looses power.
  5. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Yes it looks like a brownout with a reset to me also
    Tabb
  6. Josh Lambeth
    1,315
    216
    Ah, I missed the receiver power going out...
    What type of BEC are you using to power your setup? I would test the output with a voltmeter to make sure it's really supplying 6V.
    Josh
  7. Andy Chen
    Oct 14, 2012
    yea...My BES is broken
    Ha...Thanks everyone ^.^
