Hi Guys, I know i read or saw a movie on this some where when I first set up the radians for the first time do I have to keep them all unplugged from each other and/or is there a specific order you have to program in? Also do I have to hook the harness from one to another to ensure proper setup? any pointers would be helpful to ensure a correct setup. Thanks
Yes, you definitely have to program them up independently. I do tilt, roll, and yaw in that order. Adjust the gains down until you get no response and then come back up, just a few percent at a time. The sweet spot can only be one or two percent wide for a given camera, so it's easy to go too high, then too low and miss the spot. Hope that helps. Andy.
If I am going through 1 by 1 to program which port to I plug the bec into each radian for power if nothing else but the programmer is in 5 and 6?
i am assuming when i do each program to each servo i am not using the daisy chain i am actually connecting each servo up to the usb controller and the power 5v power to each radian also
