Find it here: http://www.freeflysystems.com/products/freefly-radian.php Video on how to update FW here: This update will fix the PWM issue some people were seeing. Best, Tabb
Will this also allow us beta testers to use this software in the same locations or should we move our Radians to the retail location? Josh
Hey guys, Tabb did some testing with the PPM and we found a small issue with the daisychaining when you are using a PPM receiver (sbus, pwm and spektrum are fine). This issue has been fixed - so it's worth holding back on the update for version 1.02 which will be up on the website soon if you are likely to need to daisychain PPM Radians. Josh: All the release versions of the software are at the new orientations - so you need to switch them I'm afraid. Don't forget to read your current config then click the 'set defaults' for each axis just to be sure.
Hi guys FW 1.02 is posted, get it here: http://forum.freeflysystems.com/index.php?threads/radian-firmware-1-02-posted.215/
