This is my setup for a WooKong flight control FC (S-BUS) for a DJI S800. I want to connect the two radian to my reciever that already has the S-Bus occupied by the WooKong FC. I currently have the left lever controlling tilt and want to leave it. (does anyone have similar configuration) Do I need to use a spektrum satellite. I do have a JR X9503 if needed. What is the best solution for me?
Hi Gmango, I think the easiest solution is to run a wire from Channel 8 on the Futaba RX (which I assume you used to run tilt with from the WKM) and plug that into port 1 on the tilt Radian. Please note that the Radian operates a bit differently on slew commands and is not proportional like the WKM is. You would need to assign channel 8 to something like a 3 position switch. When you have it in the middle tilt will not slew. Up on the switch raises the tilt, down would lower the tilt. Hope that helps! Tabb
