Quick Release Camera mount
Discussion in 'CineStar FAQ - Tips and Tricks' started by Jei Swan, Feb 17, 2013.
  1. Jei Swan
    Jei Swan Member
    Jan 6, 2013
    102
    Just took the day to balance a manfroto quick release plate to my gimbal. wondering f any one else has done this and what results you have had. I did it for the ease up changing settings and to change the battery. Havent flown it yet 35 mph winds today.
  2. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    This is the 507 i baught the 323 that is smaller... its half the weight..! :) :)
  3. Gary Haynes
    Here's the info on the Adjustable Camera Rail from FreeFly. I've flown this with both the Sony that is shown and my Nikon D800. It makes balancing the gimbal much easier. Here is an example with the NEX7. The center balance point was on the back edge of the tilt cross bar. And that is a position that unless you do something like putting spacers under the mounting plate, add a smaller 1/4x20 screw, you can get closer but not dead on. I did all of that and the camera would not maintain tilt angle.
    So here's the answer. FreeFly has an Adjustable Camera Rail. The rail itself is machined aluminum. Very light but very strong. Very easy to install. Take off the old mount, put the new mount on and adjust for level. Mount the rail to the camera. Slide it into the mount. To lock it down there are 4 screw bolts on the bottom side, two for each side of the rail. Tighten them down after you find the balance sweet spot and it isn't going to move.
    Besides giving a perfect balance you have the added benefit of being able to quickly mount or remove the camera for battery changes, card changes, etc. Put a small mark on the bottom of the rail next to the front edge of the mounting and you can easily slide it in with quick indexing of the original spot.
    And much less weight than flying a standard camera quick release, like a Manfroto.
    And the delta weight between the Adj Rail vs the standard mount is only a few grams.
  4. Colin Snow
    Colin Snow Active Member
    259
    26
    Hi Gary - When will this be available? What is the MSRP?
    Colin
  5. Gary Haynes
    Colin check with QC. They are available now.
  6. Colin Snow
    259
    26
    Before I posted my query I hunted around their website and didnt see it. I checked again just now in the obvious places e.g. under camera mount and stll dont see it - only the std FF Camera Mount. I will ping them tomorrow and post a link if they have it up.
  7. Pavlos Antoniou
    Oct 6, 2012
    321
    18
    So its with screws? Ots not a real quick release??
  8. Gary Haynes
    Pavlos, yes it is with 4 screws. Personal opinion is that it only take a few seconds to release them. Looking at the complexity and weight of a true 'quick' release and the way it clamps (typically a dovetail clamping from the side) this rail system from FreeFly does the same thing in a much lighter, simpler package.
    Colin I don't think they have it on their website yet. Did you call or chat them online?
  9. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Hi Guys, We developed this part to be a quick release alternative but much much ligther and a more secure (IMO) clamping method.
    Best,
    Tabb
  10. Colin Snow
    259
    26
    My chat with QC: It will be available early next week...prior to Wednesday.
  11. Steve Maller
    Thanks!
  12. Steve Maller
    Thanks, Tabb. On a related matter, do the adjustable tilt bars (V2) provide more up and down adjustment than the standard bars? My Sony CX760V wants to sit higher up in the saddle (so to speak) than I can easily do with the standard bars on my 2-axis gimbal. If o, then that plus the new camera mount will be a Very Good Thing.
  13. Tabb Firchau
    Jun 28, 2012
    911
    472
    Hi Steve, I think the dual adjustable tilt bars don't allow for any more UP adjustment then the stock bars but like you say you get a bit more height by using the adjustable camera rail so I think the CX balances perfectly with the adjustable camera plate.
    Thanks!
    Tabb
  14. Steve Maller
    Thank you, Tabb. Are the plates available anywhere now? QC says it's another week or so before they have them.
  15. Colin Snow
    259
    26
  16. Steve Maller
  17. Colin Snow
    259
    26
    Here's a pic of the FF Adjustable Camera Rail mount with my Sony CX760. This is a good product. It solves a problem I had with the standard FF mount for this camera. Because the tripod receptacle is in the center (left) bottom of the camera the mount screw 'interfered' with gimbal cross bar. Now I can balance the camera per Jeff's video below.
    I note one caveat: there is only one hole and it is at the end of the slider. So, as you can see, it extends way out front of this camera. Because of that I could not use any other lens hood other than stock, otherwise the slider interferes with it. A suggestion for v2 of this product is to put another hole in the center.
  18. Gary Haynes
    Colin hard to tell but would it mount ok if you reversed the direction of the rail, pointing it to the back?
  19. Colin Snow
    259
    26
    I did that first and found that the rail obstructs tilt down.
  20. Gary Haynes
    Well that woudn't work so well.
