when i am in OSD mode I have all of my bls on the right, the letters and number are white, temp and amps, when i turn on the motors, some of them turn yellow for about 2 seconds, then go back to white. any idea whi this happens?
Probably due to either a current surge at start or temps. Probably a warning. As I found out yesterday when I was checking my balance through the 3D window the little balance square turns yellow and even red probably to indicate that your balance is slipping out of tolerance. But it isn't documented anyplace that myself or Andy could find.
Worse yet, Jean Gabriel, because MK does not make the source code of MK Tool available (or if they do, I don't know where to find it), there's no way I can dive into the code to get an answer for us. Andy.
