Question: same to you?
Discussion in 'Movi Technical' started by Frank Algermissen, Jun 29, 2018.
  1. Frank Algermissen
    Frank Algermissen Active Member
    Jan 9, 2018
    136
    39
    Hi,
    maybe it's "just" a cosmetic thing but I wonder why my MOVI has this "touch to the right" when switched on and without any mobile attached.
    Please have a look to my pics which shows that one of the motors is not directly in the middle and also the clamp hang a little bit to the right.
    Is it possible to calibrate? Or is it just normal?
    Frank:
    When no phone is present in the gimbal, the Movi is not actually stabilizing -- it just moves to a sort of "demo" position...
  3. Frank Algermissen
    Jan 9, 2018
    136
    39
    Hi,
    simple question: does your MOVI stays in same/similar "demo position" ?
    Simple answer: Yes. They all do. :)
  5. Frank Algermissen
    Jan 9, 2018
    136
    39
    Okay... so it seems not to be a personal issue but seems to be normal
    Yes, as far as I can tell, based on all available information, it is the intended behavior when there is no phone mounted in the Movi.
    Hope that helps re-assure you.
  7. Tony Walters
    Tony Walters New Member
    Jul 5, 2018
    I just received my MCR today, and it does the same, with the phone in place
  8. Frank Algermissen
    Jan 9, 2018
    136
    39
    Ok Tony, many thx for your feedback. That calms me down cause it shows that this is no individual issue with mine but a normal behaviour. Puhhh...
  9. Andy Johnson-Laird
    I suspect it was designed that way so that FF could have several MCR's on a tradeshow booth and people can put their own phones into them -- but that's just me speculating....
  10. Deniz Ozgoren
    Deniz Ozgoren Support Mage
    Dec 17, 2015
    273
    84
