Progressive RC "The Dual Threat" 2000 Watt Charging Station
Discussion in 'Sale / Trade' started by tlanghor, Feb 4, 2020.
  1. tlanghor
    tlanghor New Member
    Aug 17, 2012
    Perfect condition Progressive RC "The Dual Threat" Charging Station. Very powerful fast safe charging. $400 buyer pays shipping which will be approx $60 in the US. This is an $800 setup. I've sold off all of my RC components and this is the last of it. I'm KaiserLow on RCgroups. 20200124_134031.jpg 20200124_134049.jpg 20200124_131350.jpg 20200124_131314.jpg 20200124_131358.jpg
    "The Dual Threat" 2000W Combo from Progressive RC. Great condition high power 2000 watt lipo charging station.
    Save $400.
    Buyer pays shipping
    Power Supply
    Mean Well RSP-2000-48 Specifications
    • Output power (220VAC): 42A continuous, 2000W
    • Output power (110VAC): 31.5A continuous, 1500W
    • Output voltage: 48V DC
    • Input voltage: 90-264V AC (worldwide use)
    • Protections: short circuit, over load, over voltage, over temp.
    • MTBF (mean time between failure): 46,000 hours
    • Efficiency: 87%
    • Active PFC (power factor correction): > 0.97 minimizes generator load and maximizes use of AC power
    Charger
    Charger 4010Duo Specifications
    • Input voltage range: 9-50V DC
    • Input current limit: 65A
    • Maximum charge power capacity: 1400W per channel @ >23.5V (up to 2000W in synchronous mode)
    • Charge current range: 0.05-40.0A per channel, or up to 70A in synchronous mode
    • Discharge power capacity: 130W per channel, or up to 200W in synchronous mode
    • Maximum regenerative discharge: 1400W per channel, or up to 2000W in synchronous mode
    • Maximum external discharge power capacity: 1600W @ 40V/40A, or up to 3200W in synchronous mode
    • Current drain for balancing: 1.2A per channel, or up to 2.4A in synchronous mode
    • Balance accuracy: 10mV
    • LiPo/LiIo/LiFe: 1-10 series per channel
    • NiCd/NiMH battery cell count: 1-25 series per channel
    • Pb battery cell count: 1-18 series (2-36V) per channel
    • PC Connectivity: USB port
    Balancing Boards
    Charge up to 12 lipos at once.
    2 FMA Multi-Port Safe Parallel Adapter for JST-XH & T-Plug
