PROBLEMS WITH MY NEW MOVI PRO AND MIMIC
Discussion in 'MIMIC' started by Christian Copaja, Jan 18, 2017.
  1. Christian Copaja
    Christian Copaja New Member
    Jan 18, 2017
    Hi everyone... I'm from Chile, recently i bought a new MOVI PRO handheld bungle and its my first time with a stabilitation camera system.
    I read all the manual and i cant configure the mimic whith the movi, i try to diferent channels in mimic and in movi pro but nothing happend...
    Please help me!!
    Open up a support ticket with Freefly Christian: email to support@freeflysystems.com.
  3. Bayena Sosa
    Bayena Sosa New Member
    Nov 25, 2016
    18
    Hola Christian, qué tal? soy de Paraguay. Pudiste resolver el problema? Si todavía no resolviste, podrías hacer un paso a paso de lo que hacés para parear el mimic con el movi?
  4. Ivan Robles Mendoza
    Ivan Robles Mendoza New Member
    Feb 11, 2017
    23
    Hey Andy,
    I already wrote you twice since last saturday concerning my issues with movi+mimic without an answer frim you guys. And since then i have another 3 quedtions.
    First: my mimic is always on red status. there are "fails reports" on many items at the monitor screen. The mimic does bind (Sometimes not always) and the movi starts jiggling. From a short distance and also from 6 meters far away between diferent rooms. Is there something that i can do to help this situation.
    Second question: is that a firmware problem or should i assume that my mimic is actually broken?
    Third question: if it is a firmware problem. When are you going to release a new one without this bug specially?
    Thanks in advance
  5. SeBaStIaN BArrEtT
    Oct 30, 2016
    343
    67
    dunno if andy works for freefly support, just moderates the boards. but im often confused and wrong.
    video helps!
    As SeBaStIaN surmises, I'm not a FF employee, just a volunteer forum moderator/administrator....
    Ivan, you might want to try calling tech support. Mrs. Google tells me that you're in Germany so just as a heads up, tomorrow (Monday) is a national holiday, Presidents Day, so FF is unlikely to be open. (And before anyone makes any inappropriate inferences, Presidents Day is in honor of George Washington. Certain States also celebrate Presidents Lincoln and Jefferson.)
  7. Graham Futerfas
    1,258
    243
    Hi Ivan, I'd also contact Support. I spoke with Florian Klaes the other day, and he's having a similar problem, where he can't get a Green status on the Mimic. I think he was able to update to the Beta firmware on the Movi and the Mimic, but it didn't resolve his issue.
  8. John P.
    John P. New Member
    Apr 13, 2017
    Good day everyone . I have read alll the posts about binding the mimic with the movi pro but I have been unsuccessful with mine. Does anyone have a list of all the settings ? Or tricks.
  9. Florian Klaes
    Florian Klaes New Member
    Oct 23, 2016
    25
    Heyo... seems until now the statement for this is: thats only a firmware bug on some m-pro bundles... if your movi is misbehaving you have to send it in...if everything else is working fine and mimic and mpro are just showing the red status...we just have to wait for a firmware fix...
  10. matias pisani
    matias pisani New Member
    Oct 31, 2017
    Hello,
    I´m having the same issue with the mimic. When I connect it to the app it has all kind of errors: Compass Fail, Barometer Fail, Gps Fail Battery Fail, Bluetooth Fail, the battery shows to be 0% when in the mimic says 90%. And when I used in mimic mode it works for a little while until it looses signal and the move starts going crazy.
    Ive tried everything, charging it dis-chagrin it, reseting it multiple times, installing the new firmware, revert it..
    I've tried a million times to calibrate the compass but was not possible. I think I´ll just give up for now...
    anyone has any idea?
    I can't send it back to FF I live in Argentina
    Matias
  11. Andy Johnson-Laird
    Hi Matias: Sorry to hear of all the issues you're having. The best thing to do is to open up a ticket by sending an email to Freefly Support (support@freeflysystems.com) -- include a link to this threade, Message #10.
  12. matias pisani
    Oct 31, 2017
    Thanks Andy, I will try that
    Matias
