Problem with tilt on the M15
Discussion in 'MōVI M15' started by Stephen Peek, May 13, 2015.
  1. Stephen Peek
    Stephen Peek New Member
    May 13, 2015
    Hey guys,
    Thanks in advance for all your help, new on the forum and finally able to get a few answers.
    I seem to have very unreliable results on the tilt, sometimes it will tilt all the way up 90 degrees, and sometimes it seems like either the motors are tired, or it's not getting full range of motion.
    I've been mainly using my Red Dragon with a CP.2 cinema lens on it, and I thought maybe it was too heavy, seems to be around 12-13 lbs w/ battery.
    But today I tried putting a 5D M3 with a Canon 50mm, super light setup, and I seem to have the same problem.
    Any advice?
  2. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    Stephen,
    Video and pictures would help to solve the problem. Is the rig balanced properly? What stiffness settings do you use for your cameras?
  3. Chris Herr
    Chris Herr Member
    Jun 20, 2013
    75
    15
    What's your max and min tilt set at? I'm assuming there are no physical blockages.
