Hi, FIRST: Im very ignorant with this drone and sorry for my english I have some problem with Gas. When I try to take off and the gas is in 10 (or some another number) of 255 the motors speed is delayed about the Gas position (i dont know if is a specific configuration or a "real" problem). This happened to me after upgrading the firmware from 0.x (i dont remember exactly version) to 2.1. Anyone know what the problem might be?
Raul: If I understand you correctly, when you try to operate the throttle stick, the motors are not speeding up? Correct? If this is the case you may need to re-calibrate the compass. Regards Andy -- Raúl: Si yo le entiendo correctamente, cuando intenta hacer funcionar el mando del gas, los motores no están acelerando? Correcta? Si este es el caso de tener que volver a Puede calibrar la brújula. mirada Andy
The motors are speeding up but not properly and not according to throttle. Now I try to re-calibrate. Thanks!
Let me know if the compass calibration corrects that problem. You might also getting the Flight Controller completely level (the battery tray is usually a good substitute for the Flight Controller and re-calibrating the accelerometers (ACC). See http://wiki.mikrokopter.de/en/Erstinbetriebnahme Step 12. Andy.
