Problem whit my 60D IR trigger.
Discussion in '3 Axis Gimbal' started by Luis Velasquez, Jun 25, 2013.
  1. Luis Velasquez
    Mar 24, 2013
    47
    Hi every one, i have my new 360 gimbal, i have 2 small problems but no experience to fix it.
    1- a litle noise on one of the servos is like and interference sound.
    2- my camera trigger don't work. No pictures.
    on the firs time i conect all direct from battery, the same problem, but afther some one tollme to conect a ESCs from 7v to 5v i conect that and the 2 problems persist. take 2 pictures whit a color graphics to show the connections.
    any idea, if need more info just tell me thanks. i like fix it soon.
    Luis which camera trigger are you using? Typically Gear is on channel 5. Have you confirmed that your transmitter is showing servo movement on Channel 5 with your camera switch?
  3. Luis Velasquez
    Mar 24, 2013
    47
  4. Matt Sharp
    Matt Sharp Member
    Apr 29, 2013
    79
    10
    Did you get it sorted out yet? 60D is one of the cameras I shoot with, and I use the gentled to trigger it.
  5. Luis Velasquez
    Mar 24, 2013
    47
    I have the problem no solution yet. how we can solve this???
  6. Matt Sharp
    Matt Sharp Member
    Apr 29, 2013
    79
    10
    The way I set mine up was to plug the gentled into the throttle channel first.
    Make sure the travel values are at 100% + and - travel.
    Make sure the camera is set to remote 2 sec.
    Align the ir led with the ir sensor on the hand grip.
    Start with the throttle in the low position and slowly move it through the range of travel. Once the camera triggers you will know the approximate end point for either taking pictures or starting and stopping video based on which mode activated. You may need to increase the end point on each channel in order to make it trigger correctly. My travel values wound up being -109 to trigger video and + 125 to trigger still pictures.
