I seem to be having a problem after using the Movi controller. when I go back to Majestic mode, and it turns on, it points camera toward the handles at around 45 degrees, instead of straight forward. Makes it difficult to operate. Any advice? Is there some setting in the app I'm unaware of? Thanks!
Stephen it's likely that handles are not aligned to 'front' on the Toad Hole. The pan motor does have a front position. So take a look at the 'hole' locking collar and see if it has the a flat side to the front of the gimbal. If so mark it with something like a metallic pen and reposition the handles.
In addition, you can always trim the pan via the app. Also sometimes if your majestic pan window is large enough, the Movi will settle somewhere in there which can give the illusion that it's not centering properly. I set my toad in the holes up so the clamp faces forward, makes it easy to remember.
