Powering Red Dragon?
Discussion in 'Cinestar 8' started by Steven Flynn, Jun 28, 2015.
  1. Steven Flynn
    Steven Flynn Member
    Apr 14, 2013
    113
    Does anyone have any tips on powering a red dragon from a lipo? I want to fly it without the handle for the RED, and I've got the power cable for the RED, but before I go off and make my own decisions, I thought I'd ask quickly to see if anyone has any suggestions for powering the camera from a lipo. ?
    Steve
  2. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    You should use only 4S lipo. Freefly M10 and M15 lipos run between 15-20 minutes on a single charge depending on the lipo condition.
  3. Steven Flynn
    Steven Flynn Member
    Apr 14, 2013
    113
    thats a great idea. I'd planned on using the 4S lipos, i hadn't thought of the movi batteries. Is the current draw ok on those little wires?
    thanks for the suggestion.
  4. Alex Fuller
    Alex Fuller Member
    Feb 13, 2014
    113
    Be careful you don't let the voltage get too low on those Lipo's. I have heard that its possible to fry the RED if voltage gets too low. I could be wrong since I don't use RED often, but thought it's worth mentioning.
  5. Steven Flynn
    Steven Flynn Member
    Apr 14, 2013
    113
    thanks alex. will do
  6. Philip Lima
    Philip Lima Member
    Feb 18, 2014
    67
    I use a single 4S battery to power my Movi, FF, Paralinx and RED Epic. They last about 25 minutes, which is fine when your flight times are under 10 minutes. I use this configuration in the air to keep the weight down and it's worked well for me. The Epic can drain the battery lower than it should go, so keep an eye on voltage as you can destroy a lipo pretty quick by draining it too far.
