Powering F5/55 on M15
Discussion in 'MōVI M15' started by Ben Hughes, Nov 19, 2014.
  1. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    Have just received my M15, what a huge improvement on the M10! Much more Robust, the quick release is fantastic as is the road in the hole. Much more refined, I'm so glad I adopted early and was able to Go Big!
    Question, how are people powering the f5/55. Is it a Vlock plate on the cross bar with the xlr running down? It's going to be heavy.. Has anyone found a good powering option that works well and saves weight? Can you power with Lipo/Freefly battery with jst to xlr cable and a lipo battery alarm?
    Ben
  2. Eric De Fino
    Eric De Fino Member
    Sep 1, 2013
    101
    14
    There are several threads covering powering solutions. Do a search please, and you'll find a lot of useful information.
    Cheers,
  3. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    I can't see anywhere powering F5 on the M15? Can you point me in the right direction?
  4. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    That's really not a great response by the way. For anyone else interested it looks like it is possible to power f5\55 from a lipo. Will upload pics when I've made the jst to right angle xlr
  5. Robert Pflumm
    Robert Pflumm New Member
    Oct 31, 2014
    10
    You are on the right track. I just did that at the Abel Cine Movi workshop and it worked good. Velcro a lipo on the camera use a lipo to D tap Movi cable and a d tap to right angle XLR.
  6. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    That's really useful. Thank you. I don't think you need the d tap in between though. I was thinking of just making jst to xlr straight though but with a lipo alarm to monitor the battery. The Movi is great, it's powering eveything else that becomes problematic!
  7. Angus Benson-Blair
    Jan 23, 2013
    150
    25
    I used the second Movi battery with a custom lead ie battery to XLR. Worked a treat.
  8. Robert Pflumm
    Oct 31, 2014
    10
    Ben. Even better. Please post picks. I will have to make one like that as well.
  9. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    Angus, did you have the power cable coming down from the second battery in the cradle? I'm going to mount on the canera so it's all contained in the gimbal.
    Robert, will try and post in next day or so. Fingers crossed it's all good!
  10. Angus Benson-Blair
    Jan 23, 2013
    150
    25
    Straight off the second tray for me but what you are suggesting makes good sense.
  11. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    Cable done, works perfectly and no long power cables from cross bar to gimbal. I can supply these cables to any f5/55 owner operators in the same position. Pic to follow
  12. Arturo Bernardi
    Aug 24, 2013
    50
    How long the 4s lipo last?
  13. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    Will let you know. I'm going to monitor it through a Lipo tester and keep fan to minimum on F5. Should be ok though because it won't be powering any ancillaries or vf etc just the camera.
  14. Angus Benson-Blair
    Jan 23, 2013
    150
    25
    It lasts a good few flights unlike powering a Red!
  15. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    Pics of custom cable powering F5
  16. Olly Meacock
    Olly Meacock New Member
    Oct 14, 2014
    24
    Great cable Ben, how do get one of those?
  17. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
  18. Ben Hughes
    Ben Hughes Member
    Nov 22, 2013
    58
    I've used a 3900 m/a battery for the camera. Getting good run times..
  19. Cam Batten
    Cam Batten Member
    Jun 10, 2013
    103
    I've got to make one of these for a shoot this week, is anyone able to post the pinout for + - on the 4 pin XLR?
  20. Wolf Schiebel
    Wolf Schiebel Active Member
    Aug 15, 2012
    254
    67
    Cam, plus is on pin 4 and minus on pin 1.
    Best,
    Wolf
