Are there any adapters, cables & plugs that we can use to power the Movi Pro off of regular 115v wall power outlet? Our application requires stationary Movi Pro and easier if we can simply power it from a regular wall power outlet. Does the Movi Pro battery plug use some standard format that we can find cables & plugs for? thnx
Ignite Digi Australia has a power adapter. Not sure if you can plug it in to 120V, but you can use block batteries that would last a long time. https://store.ignitedigi.com.au/col...tes/products/movi-pro-power-adapter-pre-order
Thank you Graham, this could work if I can find a suitable 2-Pin LEMO AC Adapter. Any recommendations anyone on a compatible 12v or 24v power adapter? ... what amperage rating is required? thnx!
You should contact them and ask. Chris and Tom are really helpful! They make several cable options. It draws a significant amount of power, from my understanding.
