Power for WKM from ff distribution board
Discussion in 'Electronics' started by Chris Theakstone, Jul 10, 2013.
  1. Chris Theakstone
    Chris Theakstone New Member
    Jul 8, 2013
    Where should we take the power for WKM from on the FF distribution board, our dealer suggested using the four outputs with the JST connectors on which I believe are 12v ? And the PMU should see flight battery voltage ? For the cut offs ?
    Thanks for any assistance
    Chris what voltage is needed or max for WKM? If you want to see battery voltage then there is a a couple of additional points where you can add a connection for a direct connect to the battery circuit. If you use the 12v from the molex/jst you will only see 12v.
  3. Chris Theakstone
    Jul 8, 2013
    Thanks Gary, yes I need battery voltage at the PMU so the WKM can monitor the voltage and land/ RTH at per set voltage
  4. Brandon Loeser
    Nov 11, 2012
    70
    Chris,
    WKM can handle up to 6S batteries so you need to connect it to that board where you're getting straight access to the batteries. I can't zoom in enough on the board to see if there's a place to solder. I'm sure there is. Can you take a picture of the board up close?
  5. Gary Haynes
    THere are at least 1 and maybe two empty pads for direct power.
  6. Chris Theakstone
    Jul 8, 2013
    Many thanks guys, found a picture on another thread which shows the solder point.
    Brandon Loeser likes this.
  7. Daniel Gowland
    Daniel Gowland New Member
    Nov 4, 2012
    13
    G'day Chris, Can you point me in the direction of the picture which shows the solder points...?
    Thanks, Dan...
  8. Chris Theakstone
    Jul 8, 2013
  9. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Bingo, thats the one. There is another pack voltage pick up point as well.
    Tabb
  10. Sean Haverstock
    Mar 6, 2013
    64
    I used that as well.
  11. Graydon Tranquilla
    Oct 8, 2013
    159
    15
    I discarded the Cinestar 8 power distribution board and used the "Super Hungry" Power distribution board as sold by HobbyKing. But I reverse engineered it a bit as it was IMHO overkill, overweight and too big to fit the way I wanted it to fit. Here it is.....
  12. Gary Haynes
    Interesting Graydon. Don't see it on the HK site.
  13. Bill Collydas
    Bill Collydas Active Member
    Nov 28, 2012
    528
    72
  14. Graydon Tranquilla
    Oct 8, 2013
    159
    15
    Super Hungry mounting
