Portable battery for Movi CR
Discussion in 'Movi Technical' started by Alessandro Guida, Mar 11, 2019.
  1. Alessandro Guida
    Alessandro Guida New Member
    Mar 4, 2019
    Which specifications should I look for on a portable battery that would be able to charge my CR?
    thank you!
    Hi Aleguida, welcome to the forum.
    As to your question, any battery that is capable of providing USB power -- so 5 volts at 1.5 to 2.0 amps. The Movi expects to be connected just to a simple USB port.
    The Ground Is The Limitâ„¢
  3. Alessandro Guida
    Mar 4, 2019
    For example if I use a Anker PowerCore Lite 20000 (Capacity: 20000mAh/74Wh / USB-C/Micro USB Input: 5V=2A / Output: 5V=4.8A (3A Max Per Port) is it ok? How many charges can I expect from the external battery?
    thank you!
    Hi Allesandro: That should work fine -- it just presents to the Movi as though it was a USB socket.
    I don't really know how many charges you're likely to get, but with 20 Amp hours, I would think "quite a few" -- it really depends on how discharged the Movi's batteries are when you recharge.
    Cheers
    Alessandro Guida likes this.
