Please help with my spektrum DX8
Discussion in 'MIMIC' started by Akpe Ododoru, Dec 13, 2016.
  1. Akpe Ododoru
    Akpe Ododoru Member
    Feb 14, 2015
    32
    Hello everyone am quite new here and would really need your help
    I have a spektrum DX8 (2.4GHz DSM) that i use for my freefly movi m5
    The "Flap Gyro" stick which controls the "remote, Magestic and off" isn't working anymore.
    Is there a way i can set it up so the "Aux 2 Gov" stick controls these functions?
    Would really appreciate your help.
  2. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    881
    70
    In the system set-up menu scroll down to "channel assign" you will see the channels assigned there then if you go to the next button down the button you can switch the flap to aux2. on the dx9 there assigned letters so it much easier but its the same process for memory
  3. Akpe Ododoru
    Akpe Ododoru Member
    Feb 14, 2015
    32
    Thanks for the reply Jason
    the only options i have in the menu are-
    Servo setup
    D/R and Expo
    Differential
    Throttle Curve
    Flap System
    Mixing
    Range Test
    Timer
    Monitor
    EDIT
    I managed to find the "system set-up" menu, but there is still no "channel assign"
    #3 Akpe Ododoru, Dec 13, 2016
  4. Jason Smoker
    Oct 23, 2012
    881
    70
    Sorry i just pulled out my old dx8 to have a look so when you power on the dx8 hold down the scroll button that will take you to system set-up then go to "SWITCH SELECT" then assign it that way. scroll down to aux 2 then change it from "Inh" to aux 1 or 2 and change your flap to "inh". you can check it working or not in the "Monitor" menu
    you probably have to go into the movi software to reassign it. afterwards
    see if that works
  5. Akpe Ododoru
    Akpe Ododoru Member
    Feb 14, 2015
    32
    Thanks a lot dude, its working now.
    Really appreciate the assistance...thanks
  6. Jason Smoker
    Oct 23, 2012
    881
    70
