SO I TURN THE MOVI M10 ON AND IT TURNES 90 DEGEES TO THE LEFT PLEASE HELP TROUBLE SHOOT THANK YOU. MY NUMBER IS 818-641-9817 ASAP THANK YOU
Hi Michael, is your M10 attached via toad in the hole ? Reason for pointing wrong direction on initializing is wrong position of the toad in the hope. Or of the handlebars if you did take them off. On my toad in the hole the clamp has to be facing front then the movi initialize to front. Hope that helps. Best Markus
yea a client was using it and he called me and I told him to loosen the quick release and move it 90 degrees so it faces straight. thank you for the quick respond
