Hi all, I've opened up a support ticket already but still wanted to post this issue on the forums. Two weeks ago I've received my Pilot Zoom/Iris module. Everything was working fine until I was on a shoot last Wednesday and my force joystick seemed to run out on me. I had it set to the roll on the Movi Pro most of the time (switching between roll and defer on the X-axis and having defer on the Y-axis). Suddenly the roll started twitching and the Movi started to bounce between two roll points. Now when I put the joysticks axis on the roll or tilt they start to drift heavily. Like there is a command being input which isn't there. Basically the joystick is useless as it is now. I hope the unit is not defect and doesn't have to be send back.
Problem solved!! Joystick just needed a re-calibration. Should have read the Movi Pilot manual instead of only the Movi Pro manual.
