In some modes the phone doesnt re-center. If i'm using say Barrel and set it to snap, sometimes if I click the trigger to get it to snap and it misses and cant find the horizon then when I right the movi, the phone is not pointing straight. I've found the only way to fix it is to go to Majestic mode then back to Barrel. I've had the issue with some other modes too. Is there a future option or maybe a current one to bring the phone to center? I know with say the Osmo Mobile, if you click the trigger twice it re-centers the phone. Thanks, Chris
Assuming you are talking about "window", here is how it is defined for each method: Majestic: You can change on toolbar Echo: Fixed at 5 degrees for all axis Movilapse: Fixed at 15 degrees for all axis Timelapse: No concept of window Orbit: Fixed at 20 degrees for all axis, except pan doesn't apply if orbit is active Barrel Roll: Fixed at 20 degrees for pan and tilt. Roll is either "hold" or "snap" Smartpod: No concept of window "If i'm using say Barrel and set it to snap, sometimes if I click the trigger to get it to snap and it misses and cant find the horizon then when I right the movi" Sorry I don't fully understand this. A video explanation would be the best.
