Pan servo wheel clearance.
Discussion in '3 Axis Gimbal' started by Tristan Twisselman, Aug 7, 2012.
  1. Tristan Twisselman
    Jun 30, 2012
    416
    25
    I attached a few pictures. I noticed in one of Tabb's gimbal videos it showed him installing spacers which would be the fix for my issue I think but my kit did not come with them. Not sure if it was supposed to or not. Thoughts? It just barely barely is touching the head of the mounting bolt to the wheel.
    [​IMG]
    [​IMG]
    [​IMG]
  2. Josh Lambeth
    1,315
    216
    Mine does this too when it's on the ground. As soon as it's in the air it spins freely without hitting it.
    Josh
  3. Tristan Twisselman
    Jun 30, 2012
    416
    25
    That's why I thought. Thanks :). I just need to quit having my spin while on the ground. Darn hover fly board
  4. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Yes, clearance is tight...but should be OK once in the air!
    Tabb
  5. Tristan Twisselman
    Jun 30, 2012
    416
    25
  6. Brad Meier
    Brad Meier Active Member
    Aug 14, 2012
    749
    66
    I found one solution is to tighten the booms down at the center clamps first then put some pressure on the outer ends while tightening the other clamps to get yourself an extra mm or so. Alternatively if you tighten all those down with any kind of weight on the structure it would go a mm or so in the opposite and definitely hit the servo wheel
  7. Bob Wojda
    Bob Wojda Member
    Sep 13, 2012
    64
    I have the same issue. The clearance is too tight and the head of the bolt just touches the wheel. If everything is dead even it's free but if the cinestar is not perfectly level, like on a windy day, the four bolts hit the gearwheel as the gimbal moves around. In the shop I can recreate it by leaning the cinestar to one side. I think is shouldn't do this. Any ideas on spacer for this or is there another solution somewhere?
    Bob Wojda
  8. Andy Johnson-Laird
    Bob:
    Check out this thread.
  9. Ros
    Ros New Member
    Apr 14, 2013
    18
    I am also experiencing the same problem with the servo wheel still hitting one of the 4 bolts at times during flight. Is there a way to give myself enough clearance to be sure this will never happen?
    Cheers,
    Rory
  10. Andy Johnson-Laird
    Rory: That's very unusual for it to hit during flight. Normally, once you get airborne the weight of the gimbal extends the silicon O-rings and there should be more than enough clearance. You can verify this by picking the Cinestar up by the booms and panning the gimbal -- or have you already done this, please?
    I'm really puzzled why it should be hitting when the copter's airborne....
  11. Ros
    Ros New Member
    Apr 14, 2013
    18
    Hi Andy,
    It definitely hits during flight and when suspended. Could the mount not be symmetrically connected?
    It only hits on one side of the gimbal cross plate, I only have about 1 kg of weight on the gimbal, however I still want to find a way to eliminate this issue even with a small load on the gimbal.
    Rory
  12. Brandon Loeser
    Nov 11, 2012
    70
    To fix this issue... when you tighten the tension on the pan belt.... rotate the servo slightly. Sometimes the tension is too tight and it causes the gimbal to flex in the middle and it sags. You can also double up on the center plate and that helps keeping the plate from sagging. No need for glue just double it up. You can see in the top picture how the servo is slightly turned down.
  13. Andy Johnson-Laird
    As Brandon suggests, doubling up the star plate will provide extra rigidity -- but it's not clear to me why the star plate only hits in one position. If you look at it from the side, does either the small pulley or the large pulley appear to be canted over? Or is one of the arms of the star plate bent downwards?
  14. Ros
    Ros New Member
    Apr 14, 2013
    18
    Hi guys,
    Now you mention it the plate does appear to maybe be bent. I guess I will take it apart and put it on a table to tell for sure.
    Cheers,
    Rory
