Quick question, I noticed that the last few days when turning my gimbal on, the pan axis rotates about 20-30 degrees and then stops. This is with the mode switch off. It hasn't always been like this. Anyone else experience this.
Hi Brad, I had this happen once on the last job.....need to investigate. It was like it was taking the module a second to 'see' that the mode switch was set to off. Tabb
The occasional panning on power-up issue is fixed and will be released shortly in the upcoming firmware 1.03. It's not related to anything else - it is because the module is trying each receiver type and can take a second or two to get to the one you are using. During this time, the pan was being switched on.
Good to hear it's already being worked on! What else will be updated in 1.03? Thanks for the hard work guys! Josh
