Would there be any possibility of adding a pan limit to the M5 so as to prevent rotation beyond a certain amount? The reason I ask is we are looking to possibly use the M5 on a multirotor setup along with DJI Lightbridge. As Lightbridge handles both video and flight control there ends up needing to be a physical connection between both elements, be it the video signal from camera to Lightbridge mounted on the MR or sbus from Lightbridge mounted on M5 to the flight controller. As such limiting the potential for winding up the cable is the concern. If we could set a limit of say 360 or even 720 degrees in a given direction it could allow for such setups. Just an idea...
