Hi, I am trying to locate this item. Is the center piece that holds the camera plate on the gear. Is a 20mm bearing shaft. I can't seem to find it on the QC website. Can anyone help? Thanks\ Bill
Has the solid gear been replaced by this one? If this is the new one then they are available at QC http://www.quadrocopter.com/FreeFly-130T-Pan-Pulley_p_673.html
I have both those gears. The solid one and this one. The solid one is 130T also. @tabb yes the 20mm bearing is damaged badly. I need to replace it. Does this mean I have to purchase another pan head? God have mercy on my bank account. Bill
Hi Bill, Just to be clear...you only need the 20mm bearing? Or the shaft as well? Gary - Yes the solid pulley was replaced by the lightweight one Thanks Tabb
Hi Bill, Ok let me do some checking. This is a difficult part to assemble. Do you have the proper presses / tooling to handle the task yourself? Tabb
