Pan arm rotated -10 degrees on start
Discussion in 'Movi Technical' started by Joern Thiemann, Jun 26, 2018.
  1. Joern Thiemann
    Joern Thiemann New Member
    Jun 26, 2018
    Hello all together.
    Yesterday I got my movi. Setting up was easy. But when I started my movi, it seems to be, that the pan arm is rotated -10 degrees. Let's say, my view direction is directly to the front, then the pan arm is 10 degrees rotated to the left. This is with our without mobile. Is this normal? Can I somehow reset or correct it?
    Best regards
    Have you tried it with your mobile installed? Just curious whether the behavior is different?
    If it's the same, then I'm not sure this will fix it (because I cannot reproduce the problem on my Movi), but try tapping on the three line icon at the top left hand corner of the screen, tapping on Robot, then tapping on the right arrow head on the right of the screen alongside Reset Robot Settings.
    Let me know what you find....
  3. Joern Thiemann
    Jun 26, 2018
    Hello Andy,
    thanks for answering.
    I tried resetting the movi three times. No success. I can upload a photo how the pan arm look later this day.
    Best regards
    Joern
    Hi Joern: Hmmm. I've not seen this problem before. It might be time for you to open up a ticket by sending an email to Freefly Support (support@freeflysystems.com) if you have not already done so.
    Cheers
  5. Joern Thiemann
    Jun 26, 2018
    Thank for the information. I already send a ticket to the support.
    Here is the photo I spoke about. Just needed to watch the end of the soccer match South Korea against Germany.
    I don't think it should be doing that!
  7. Joern Thiemann
    Jun 26, 2018
    Okay. Let's see. I will update you on that. Maybe this will someone also help.
  8. Andy Johnson-Laird
    Indeed it will help if someone else has the same problem -- as you say, please post again when you have an update.
  9. Frank Algermissen
    Frank Algermissen Active Member
    Jan 9, 2018
    136
    39
  10. Kevin P Riley
    Kevin P Riley Active Member
    Jun 21, 2018
    136
    29
    What is your window set to? Mine will do that and will also not return 100% to the middle (after a turn) if there is a window set. The bigger the window the more pronounced the offset. If I select no window, it returns immediately to the correct position.
  11. Frank Algermissen
    Jan 9, 2018
    136
    39
    I don't have any window set. But it's interesting when "ROLL" is active and when not. Compare the two screenshots below and this screenvid here https://d.pr/v/qT2K9t I just quickly did it to show what happens after switching the MOVI on and click on "ROLL" or not. The "horizont" isn't horizontal even the MOVI stands on a flat ground.
    Nevertheless my point also here https://forum.freeflysystems.com/index.php?threads/question-same-to-you.12456/ is a bit different. I wonder why the MOVI motor isn't centered when no smartphone is attached o_O
  12. Andy Johnson-Laird
    Frank: I don't have an answer for this I'm afraid -- but my Movi does the same thing.... I'm pretty sure that it's an issue that FF developers are aware of, though.
  13. Frank Algermissen
    Jan 9, 2018
    136
    39
    Well Andy, first of all it just interest me if I am the only one or if there are also other customers like me/us. Secondary I'd like the know why it is so. If it's a bug, if it's "normal", if FF is already working on this... Just a statement, you know.
  14. Andy Johnson-Laird
    All good questions, Frank. But, at least for the moment, questions I don't know the answers to. I would have thought, were this an issue for several Movi owners, we'd have seen more questions about it on the forum -- but that is a rather imprecise indicator.
  15. Kevin P Riley
    Jun 21, 2018
    136
    29
    Mine also does the same thing when the roll is unlocked.
  16. Frank Algermissen
    Jan 9, 2018
    136
    39
    Well, maybe I am just more "picky" than others :D
    So maybe while we wait here for more users with the same issue (one we already have, see @Kevin P Riley ) you kindly can check that with your direct contact to FF support, as long as they don't already read (but don't react)? You know, I don't like to lead to a new set of problems - as long it's just a cosmetic thing (I am talking about this here https://forum.freeflysystems.com/index.php?threads/question-same-to-you.12456/ = MOVI motor isn't centered when no smartphone is attached o_O)
    The rest, means part 2 of my concern is "ROLL" activated/deactivated is nevetheless something too I am wondering about. It's not extremely critical al long as the result while filming is okay. Call me "balance freak" but I didn't buy a China peace of plastic where I would excuse it but a gimbal from of of the most competent film equipment companies - for about 300 €.
  17. Andy Johnson-Laird
    Frank: The best way for you to get this resolved for your specific unit is to open up a ticket by sending an email to Freefly Support (support@freeflysystems.com) -- feel free to cite back to this thread too.
  18. Frank Algermissen
    Jan 9, 2018
    136
    39
    Andy, of course I know to open a ticket. My hope was that most of you guys here will say "Hey, same to me, stay relaxed, seems to be normal". If so then I would accept it as "normal" and no need for a ticket.
  19. Kevin P Riley
    Jun 21, 2018
    136
    29
    This is what mine does, similar to Frank's but the opposite direction.
    Not sure it matters that much to me, I am not sure I will ever shoot with roll unlocked anyway, but if I did...isn't that the point, for it to roll. I would want it fixed if it can be fixed in a firmware update, I don't know that I would go to the trouble of exchanging it. it also does not seem as pronounced on the beta firmware.
  20. Andy Johnson-Laird
    Sorry, Frank. I think you may have misconstrued my response. What I meant was that, if you truly want to put your mind at ease, then the most certain way of achieving that would be to ask FF directly by means of an email. (And I confess that the part about "open up a ticket by sending an email to Freefly Support (support@freeflysystems.com)" is a keyboard macro that I use because I got fed up with typing that phrase countless times, so I got lazy! :)
