Other Gimble Applications?
Discussion in 'Camera Mount Misc' started by Patrick, Sep 19, 2012.
  1. Patrick
    Patrick New Member
    Sep 19, 2012
    Sorry if this has already been posted, but has anyone played with mounting the 2 or 3 axis gimble on other things like jibs, vehicles, dollies?
  2. Josh Lambeth
    1,312
    213
    I have thought about using mine as a handheld rig... haven't tried it yet though.
    I also have been wanting to figure out how to mount it to a jib.
    Josh
  3. Patrick
    Patrick New Member
    Sep 19, 2012
    Awesome, please post anything you do try. All I have is the gimble, I'm trying to deside the best and cheapest way to go about a ground station and operating system. The only thing I am set on is the dx8 transmitter
  4. Wolfgang Armin
    Wolfgang Armin Active Member
    Sep 20, 2012
    291
    25
    I have a crane with a very heavy motorized head that I mostly use for a 5DIII. I was thinking about using the gimbal, especially with the radian pan stabilization this could be a real cool thing. Also using the much lighter weight would mean using way less counterweight.
    What stopped me from doing it up to now is the disassembling of the cinestar.
  5. Tommy - KnightDesignDev
    Sep 18, 2012
    38
    Funny, the team here at EAI has been talking about that also.
    We are going to take a CraneII gimbal and a 3s 5000mah / GoPro and mount it onto a 20 ft painters extension handel (pole )...
    I'll post the results after our CS8 is up and running.
  6. Duane Bradley
    Duane Bradley Active Member
    Dec 6, 2012
    212
    26
    I've used my 3 axis handheld with decent results. Really removing 8 small bolts is no hassel to have a 'steady' cam. One step further will be making a bar that the gimbal can attach to, so I can adjust the height from lo-mode to high and still be able to hold the bar in the same spots. I know how to do it, just need to order the right boom connector and find an appropriate bar.
    MIke Magee likes this.
  7. Gary Haynes
    Try a telescoping painters rod if you want to so something inexpensive. Try this one Shur-Line 06572L Easy Reach Extension Pole, 4-Feet to 9-Feet I use it for holding a strobe with a beauty dish on it.
  8. TROU BAYLISS
    TROU BAYLISS Member
    Mar 3, 2013
    37
    U will see other some" other gimble applications "from me soon google ..FLITTELINE NEW ZEALAND i normaly 180 kilos stablised
    cheersTROU BAYLISS
  9. Sam Slape
    Sam Slape Member
    Oct 8, 2012
    172
    Has anyone got some radian gain settings that are working well with the 3-axis gimble as handheld?
    Poor mans MoVI wanted!:)
  10. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    835
    66
    We use our gimble on a ballon sometimes, just to need to crank down the gain settings on the pan module to get to go 360!
  11. Sam Slape
    Sam Slape Member
    Oct 8, 2012
    172
    Even to use as a two axis is what I'm trying to perfect first. I'm finding the gains are too low for the stab to be good enough yet when the gains are increased the roll axis oscillates easily in your hand unless you hold it real firm.
