Optical Stabilisation on the XS and XS Max
Discussion in 'Movi Technical' started by Rorick Edge, Oct 2, 2018.
  1. Rorick Edge
    Rorick Edge Active Member
    May 11, 2018
    452
    81
    Interesting comment from Taab Firchau at 4:40 (see also 6:23):
    What's not clear is whether what he sees as an improvement is the result of the phone or iOS 12, and how this affects using the Movi, if at all.
    #1 Rorick Edge, Oct 2, 2018
  2. Christian Robinson
    Christian Robinson New Member
    Oct 2, 2018
    Thanks for sharing this Rorick. I'll watch the full video tonight.
    Rorick Edge likes this.
  3. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    I can confirm that the OIS on the XS and XS max works much better than the iPhone X! I see very few of the little disturbances now when shooting. I think Apple significantly increased the power / bandwith of the OIS system for this revision which really helped. I will keep begging them to get rid of it all together!
    Edrolfo Leones and Rorick Edge like this.
  4. Christian Robinson
    Oct 2, 2018
    Thank for the confirmation Tabb.
    [​IMG]
    Disappointment trampled my excitement like a Clydesdale channeling Gregory Hines when I realized the 8+ could not deliver the imagery I specifically purchased it to create. It also spurred on a year of experimenting to find a solution.
    I had accepted keeping the iPhone 8+ after testing the magnet mod, but now... I might have to reconsider.
  5. Andy Johnson-Laird
    10,366
    Christian: Sorry to learn of your disappointment, but I compliment you on your metaphor: "Disappointment trampled my excitement like a Clydesdale channeling Gregory Hines...." At least that gave me a smile for today....
    Cheers
    The Ground Is The Limitâ„¢
  6. Rorick Edge
    May 11, 2018
    452
    81
    Interesting whether this is also true, as it should be, of the just-released XR.
    John Chu likes this.
  7. Andre Yew
    Andre Yew New Member
    Jan 30, 2019
    Hi guys, I shot a test this weekend on an iPhone 7+ and the MCR (in Filmic Pro). I'm wondering if the little surges you see in my video below as I'm pulling out on the building with the pink columns (about 12 seconds in) is a result of the iPhone's mechanical stabilizer interacting with the gimbal. It sounds like using a Xs could fix this problem?
    There's also a weird robotic transition after the barrel roll begins, around 21 seconds in. Could this be a stabilizer interaction issue or do I just need to practice my rolls? Since I shot with Filmic, the MCR was in its default majestic mode, though with custom autotuning and zero window response time in the Movi app before. Thanks for any help!
