Old pulley
Discussion in '3 Axis Gimbal' started by Gustavo Rios, Sep 28, 2012.
  1. Gustavo Rios
    Gustavo Rios Member
    Sep 28, 2012
    236
    Hi, I buy 2 axis gimbal first and then acquired the gimbal adapter kit, I have the old pulleys, as I can do to put the Radian, in one no have holes and the other does not fit the mounting plate.
  2. Josh Lambeth
    1,315
    216
  3. Tabb Firchau
    Tabb Firchau Administrator
    Jun 28, 2012
    911
    472
    Hi Gustavo, perfectly OK to double stick tape the Radian to the old pulleys if you do not feel like upgrading!
    Tabb
  4. Gustavo Rios
    Gustavo Rios Member
    Sep 28, 2012
    236
    Thanks Josh,
    Thanks Tabb, is a simple solution that really I did not see.
    Gustavo
  5. Arthur Vieira
    Arthur Vieira Flight Squad
    185
    24
    Just a complement...​
    1 - Use a good double side tape and before you glue it to the pulley, clean it (the pulley) with alcool or similar to take all dirty and grease out of it. A Radian getting loose in midair is not a beautiful sight I suppose. :)
    2 - Use a "hard" double side tape. I've tried those R/C Gyros Double Side Foam Tape but I got an unpleasant effect. If the double side tape is too soft, the Radian weight + the cables will make it shake a little, very little indeed, but enough to make the footage shaky. Remember you don't need a vibration proof tape as the Gimbal is already mounted on dampers.
    Just my 2 cents. Good Luck. ​
  6. Gustavo Rios
    Gustavo Rios Member
    Sep 28, 2012
    236
    I have the double side tape that comes with the kit radian
  7. Andy Johnson-Laird
    Oh, the tilt Radian coming loose in flight looks just fine.
    On the other hand the tilt Radian flapping loose and making a Canon 5D flap back and forth doesn't look fine at all.
    And a Cinestar pitching uncontrollably looks very, very bad.
    AMHIK.
