Hi there! Im in proces of converting my flat oko in to a coax. I ve done al mixing in the mixer, test 1 with no props and ok. There is conection between Tx and Rx Im even geting telemetry. Checked koptertools, Im on Graupner Hott. Solder on Fc Ok... and I just tried it 5 minuts ago and it was all good
Ok, found it! This whst hapend: NFO - SUMO 12 Setting If you hold down the button (accidentally) at the receiver while connecting, the "SUMO 12" setting will be deleted. This can be also happen if you connect the receiver with a powered up Mikrokopter and hold down the button. In this case you have to set this setting again. If you don't have a number behind SUMO, you have to update the transmitter. How to update the transmitter you can see here: Update
