Is it possible to set the MoVI up to run an external rx that is NOT 2.4ghz? I would like to use my EZ-uhf rx which utilizes a PPM or direct connection. Is this possible into the MoVI? Or do you have to use satellites? If not, could I use an old 72mhz approach? I prefer to use 2.4ghz for my FPV feed and I think it is screwing up the MoVI 2.4 (spektrum) rx signal.
