No Control with the Controller
Discussion in 'MōVI Controller' started by Rich Savage, Oct 21, 2014.
  1. Rich Savage
    Rich Savage New Member
    Oct 2, 2013
    Hi peeps,
    I bought the new controller for our M10. Everybody hated the old one. I've followed the installation instructions from the manual, but I've got nothing. The reciever seems to know it's there but neither items are talking to each other. How can I make this work?
    Cheers!
  2. Eric De Fino
    Eric De Fino Member
    Sep 1, 2013
    101
    14
    Did you set the MoVI to 'MoVI Controller' using the Configurator app?
  3. Rich Savage
    Oct 2, 2013
    Yes. That was the first thing I did.
  4. Eric De Fino
    Eric De Fino Member
    Sep 1, 2013
    101
    14
    Confirm that both the receiver and the controller are on the same channel, and select 'Pair' in the controller. I think it's under TX Config (not in front of Controller right now)
    Hope this helps.
  5. Rich Savage
    Oct 2, 2013
    Can't find Pair, but can find bind in radio config. Nada. Tried various channels, various power, Firmware Update, binding at both ends. It's driving me mad. Anyone from freefly out there?
    10,356
    1,161
  7. Richard MacDonald
    Jul 11, 2013
    94
    15
    Had the same issue today but didn't see the Fix. This is from FFS and it worked for me.
    You can be bound to the receiver, and see the MōVI telemetry and change settings (like running autotune) without being able to control the gimbal. Usually this is because the MōVI, in your case your new M15, doesn't have the Radio Type set to MōVI Controller. This will have to be adjusted from a computer or android device, Configuration::Remote Controller Config::Radio Type::MōVI Controller.
  8. Sean Jensen
    Sean Jensen New Member
    Jul 11, 2015
    So, I've done what Richard suggested and... "MOVI Controller" doesnt even show up on the iPhone app. All the other options do. What's that all about?
    I downloaded the app to my computer and the "MOVI Controller" option was on that. Weird. I got it working but when I shut the app down and disconnect from Bluetooth the controller stops working. Does the MOVI not work when not connected to a computer/device or am I missing something?
  9. Andy Johnson-Laird
    10,356
    1,161
    Sean: The MōVI does NOT need to be connected to a computer/tablet or anything else for it to work correctly. After you disconnect the app from the controller, if you power cycle the M15, what do you see happening on the three LEDs?
  10. Sean Jensen
    Jul 11, 2015
    Hi Andy. I think I figured it out. I didn't save the changes in the app before I shut it down. It looks like it is working perfectly now. Thanks.
    I've been a Steadicam operator in film and TV for over 20 years and there haven't been many 'toys' that have wowed me in that time. The MOVI definitely does.
  11. Andy Johnson-Laird
    10,356
    1,161
    Glad you figured it out, Sean.
    Remember to walk like Groucho Marx -- the MōVI can remove rotation around each of the three axes, but it cannot remove motion along the axes -- e.g. vertical up and down motion.
