Newbie with a tilt issue
Discussion in 'MōVI M5' started by kim cook, May 20, 2016.
  1. kim cook
    kim cook New Member
    May 20, 2016
    Hi everyone,
    I am new to movi's and gimbals in general. I balanced a canon 5dmiii and it was working great. The I added a monitor with a cord, balanced again, and realized I need to purchase a softer cord. I removed the monitor, rebalanced the camera and now the camera is tilted all the way forward(lens pointing down). I reset all the settings to default and auto tuned again. When I turn the movi on it stays in the lens down position. I am pretty sure this is a simple fix, but I am still nervous to really mess with anything until I know what I am doing.
    I really appreciate any response and patience.
    Kim
  2. Rick Surad
    Rick Surad New Member
    Dec 17, 2015
    11
    In the movi app if your "tilt mode" is set to "tilt lock" (which it sounds like it is) you can simply apply pressure to the camera cage and move it to any angle you'd like. Its designed so it will always hold what ever tilt angle you have. Simply move it with your hand until its where you want it.
    Hope that helps!
  3. kim cook
    kim cook New Member
    May 20, 2016
    Hi Rick! Thanks so much for the tip. Yes that was it! I am getting more comfortable working the Movi now. Thanks again.
  4. Rick Surad
    Dec 17, 2015
    11
    Glad to hear it worked out!
