How do i switch between pan 1 and pan 2, tilt 1 tilt 2, etc. I have my aux 2 set so that I can turn the stab off, have it auto compensate roll and tilt at 10 degrees or whatever it is with no slew, then auto roll, control tilt and control pan. How can I use pan 2, tilt 2, etc so that I can have a slower slew rate? is this possible and i missed it somewhere? Thanks
NO you dont do something or Radian... You change mode on TX.. For instance if you are on Heli mode then you can use idle 1 idle2 idle 3 and ATvs... If you are on airplane mode then you can use Dual rates..!
