NEW U7 motor tmotor
Discussion in 'Cinestar 8' started by kjetil tønnesen, Nov 22, 2013.
  1. kjetil tønnesen
    Aug 16, 2012
    417
    23
    hello i want to build a new heavylifter with long fligthtime and i wounder about the new serie from tmotor
    U7??
    anyone have some tips?:)
  2. Peter Gøthche
    Aug 21, 2012
    136
    14
    Hi, take a look at kopterwox facebook page. He just build a x8 with U8 motors and 28" propellers. +40 min flighttime
  3. kjetil tønnesen
    Aug 16, 2012
    417
    23
  4. Steve Maller
  5. Gary Haynes
    Perfect size for a Phantom. Make it easier for it to go home. ;)
    Scott Strimple and Steve Maller like this.
  6. Nathan Reim
    Nathan Reim Member
    Oct 20, 2012
    112
    these are great my friend dan is a dealer for tiger motor here in nc and these are awesom
  7. Andy Johnson-Laird
    One of those motors, two props, who needs a frame set? ;)
  8. John Gore
    John Gore Member
    Jul 24, 2012
    93
    15
    Mine will arrive soon. :D
    Anyone else here building with U7 motors yet? Keen to share experiences and tests, etc.
  9. Chris Fox
    Chris Fox Active Member
    Apr 14, 2013
    463
    86
    U7 and U8 ordered in December .... Expecting some to arrive later this month ... ;)
  10. Dave King
    Dave King Well-Known Member
    Dec 24, 2012
    2,712
    311
    Chris which U7's did you order?
  11. Chris Fox
    Apr 14, 2013
    463
    86
    G'Day Dave,
    I went for the 490kv option and have both the 17 and 18" props to test out with them.
    I have a set of 550mm booms, but am interested to try a coax setup as well.
    Cheers
    Chris
  12. Dave King
    Dec 24, 2012
    2,712
    311
    Thats a big boy motor. I am interested in trying a coax setup too with 16" props with the U5's.
  13. Chris Fox
    Apr 14, 2013
    463
    86
    Hoping to achieve good results with headroom to spare. I'm finding the predicted results from eCalc have not been as good as expected with the last build, so hopefully this time around the performance will be what I'm after.
  14. Michael McVay
    Michael McVay Active Member
    Dec 31, 2012
    416
    91
    I also have some 490KV U7s but have not figured out what I am going to do for motor mounts for them yet. They are so large that they do not work with the standard or heavy lift mounts from QC. In another thread, Patrick Thompson put a design out there for them, but to work in a coax set up I think we need to space out the boom clamps a little further to get access to both ends of the bolt. In addition to using metal frame clamps, I was wondering if anyone thought it was prudent to use 2 clamps on each end of the mount to make sure there is no slipping. If anyone has a source to have these cut from carbon fiber please let me know. I am anxious to try these out. Attached is the specs on thrust from Tiger for anyone who has not yet seen them.
    Thread discussing mounts:
    http://forum.freeflysystems.com/index.php?threads/cinestar-6-and-long-fligth-time.2462/page-3
  15. Chris Fox
    Apr 14, 2013
    463
    86
    G'Day Michael,
    Have you tried the carbon mounts that Gary mentioned from famous hobby, they look longer than most other mounts, and may get the press nuts out from under the motor base?
    Cheers
    Chris
  16. Dave King
    Dec 24, 2012
    2,712
    311
  17. Michael McVay
    Dec 31, 2012
    416
    91
    Could someone who has the famous hobby motor mounts measure the distance between the insides of the press nuts? I'm trying to find out if they could be used on U7s. Thanks!
  18. Steve Maller
    I hope this helps. :)
  19. Michael McVay
    Dec 31, 2012
    416
    91
    Sure does...and they are just close enough to give them a try and keep my fingers crossed.
  20. kjetil tønnesen
    Aug 16, 2012
    417
    23
    i have got mine u7 motors and a will buidt a coax with 17" and dji a2
    i have not started jet ,but i will:)
