New movi-firmware update fails - sd card
Discussion in 'Movi Technical' started by Sergio Solorzano, Jul 24, 2019.
  1. Sergio Solorzano
    Sergio Solorzano New Member
    Jul 23, 2019
    Hi !
    New here, just got my movi cinema robot. I am trying to update from fmware xx to xx but at step 2-6 fails saying Check SD Card
    I have read in forums to replace sd card, which one? Movis or mobile? I dont use sd on mobile.
    I cant find a spec of movi to check if it has an sd card and where? Does freefly send a new non-faulty?
    Please help :)
    Thank you
    Sergio
    Sergio: Is the SD card in the Movi. But before you discard it, try reformatting it on a PC as a FAT (File Allocation Table) system, then re-copy the firmware on to the SD card and try again.
    Hope this helps
    The Ground Is The Limitâ„¢
  3. Sergio Solorzano
    Jul 23, 2019
    Hi Andy,
    Yep the card is in but reformating it didn't help, what do i do?
    Thank you for your help, Sergio
    The only thing for it is to try a new card -- format it too before you put it into the Movi though.
  5. Sergio Solorzano
    Jul 23, 2019
    Hey Andy,
    I tried a few times again and found my reader was bust. Bought a new reader and the update worked :)
    Thanks a lot for your help ! Cheers!
