Hi Everybody, Just got the bundle yesterday with case and remote and I can't wait to use it for an upcoming wedding! I did a search and I couldn't find anything and I apologize if it's been discussed multiple times before, but is there a way to use a Manfrotto rapid connect adapter with the M5? I just want an easy way to go from the Movi to sticks or monopod. Thanks in advance!
Scott technically you could mount the rapid connector to the MoVI slide and then slide on the camera. You would just need to see if you have the room (height) and don't exceed the weight with the camera and lens combo you are using. And being to balance the setup. Downside may be introducing more physical points of contact resulting in movement of the camera from the multiple connecting points.
