New item from QC
Discussion in 'Cinestar 8' started by Gary Haynes, Apr 21, 2014.
  1. Gary Haynes
  2. Dave King
    Dave King Well-Known Member
    Dec 24, 2012
    2,712
    311
    Saw that last week. I would try it but I have my nav/gps boards on top of my flight control board and the cap wouldn't be high enough.
  3. Steve Maller
    It looks great! Unfortunately, like Dave, I can’t use it. I just wish I had 24 hours with somebody’s Makerbot...I know exactly what I want/need, and I’ve already got it designed in Blender. I just need to revisit with somebody who knows 3D printing.
    Any SF Bay Area peeps who might be able to help out? :)
  4. Brad McGiveron
    Brad McGiveron Active Member
    Jul 7, 2012
    396
    65
    Looks perdy! too bad its not very practical for most folks.
  5. Ozkan Erden
    Ozkan Erden Distributor
    Aug 3, 2012
    678
    131
    This is something which we should have had long time ago! Some painting skills will turn the Cinestar into rockin' superstar.
  6. Jason Smoker
    Jason Smoker Active Member
    Oct 23, 2012
    881
    70
    Hey how does this go with raising the heat of the pcb? I tried different things and all it did was yeah it was great for sun,dirt etc protection but I did see a considerable raise in my temps! :( when flying.
  7. Steve Maller
    That is definitely going to be a problem, especially in warm climates. Some folks have put fans on their PDBs. But you have to be careful with that with power consumption and possibly even radio interference. However, I’m running the new Double MK board at 6S with the integrated cooling plates, and it’s a wonder. Barely above ambient temperature even under pretty heavy loads.
  8. Ozkan Erden
    Aug 3, 2012
    678
    131
    What about drilling some holes and painting it to white for heat problems?
  9. MIke Magee
    MIke Magee Active Member
    422
    103
    I just ordered one to try. I also have the Double Quadro/6s setup. I'll post some results after I get it going. Beats the shower cap, but I'll miss the little yellow ducks on it.
  10. Steve Maller
    As for me, that would defeat the purpose of it being a moisture barrier. I’m looking for a solution that...
    1. hides some of the wiring so it looks more tidy
    2. protects against some degree of moisture and other unwanted things
    3. provides some degree of protection in a roll over
    I can’t use this one, anyway, because I have a completely different center hub config.
  11. Ozkan Erden
    Aug 3, 2012
    678
    131
    Mike, I think you will be the one who will sacrifice to experiment if it heats up or not :)
    I will paint to white as soon as it arrives. I have done it before to CX4 canopy from Droidworx, it worked good on a normal lift copter.
  12. Andy Johnson-Laird
  13. MIke Magee
    422
    103
    I can always count on you Andy for interesting explanations. Maybe flat black on the inside and silver on the outside?
    -m
  14. Andy Johnson-Laird
    All depends on whether you're going to be flying in bright sunshine, Mike. That will determine whether there is more energy coming from the sun than is being emitted by the avionics.... I would also experiment with some ventilation slots to try and get some active cooling going on..
    Makes you feel you cannot beat the Universe, doesn't it? ;) (and you cannot -- so settle for break even).
    If it's sunny I would fly the copter naked, but if you're worried about precip or condensate on a cloudy day then go silver, but at all times try and make it look fashionably tasteful... :)
  15. Ryan McMaster
    Ryan McMaster Active Member
    Mar 8, 2014
    289
    40
    Reno here Steve, I have access to a Fortus 400/few makerbots=)
    Steve Maller likes this.
  16. Jason Smoker
    Oct 23, 2012
    881
    70
    Mike how did you go with the cover?
    anybody rocking these? any problems?
  17. MIke Magee
    422
    103
    Hi Jason. I've used this on the X8 with the Herk and tall MK stack in the center. Works OK, but I still don't fly in the rain because the Movi would take a hit underneath.
    -m
